1 - 4 of 4 Posts
Ok I have a 2005 Ram 1500 with 5.7L hemi. I went a 14.77 on street tires with a 93 octane tune from my Diablo Trinity. I was only at 4200 through the traps and no traction off the line. I wanted to get closer to running under 14 so I put in an 8.75" rear-end I had with 4.86 gears, threw on some slicks & headers, and now ran a 14.02 yesterday at 96.7mph. Problem is that it is shifting into overdrive WAY to soon. Like around 5200 to 5300. I have turned the overdrive button on and off and it had no difference on the track. Overdrive kept coming in early. I found on the trinity where I can change the 1-2 shift point and the 2-3 shift point, but cannot find anywhere to delay the overdrive kicking in. There is no reason I should not be able to set the 3rd gear to overdrive change at at least 5800. What should I do? I should be hitting the 1/4 mile at about 5600-5700 in third gear and not a lower rpm in overdrive. Any help or advice would be appreciated. Also, I thought if there was not a way to change the overdrive shifting from the computer that I might be able to unplug an overdrive sensor on the transmission to physically/mechanically keep it from kicking in?
I believe it has to be manually shifted to avoid the overdrive. hopefully chefred or kay9 will chime in and i'm sure they know for sure
Discussion Starter · #3 ·
Yes, that is what someone else told me as well. I am a little nervous about doing that as I do not want to shift down, over-rev it, and damage the transmission. but I have also heard that repeated full throttle over-drive shifts are not good for the transmission either.
Yep try to keep it out OD when going WOT as well as 2nd prime downshifts. 125k on my stock transmission and even though it is not a "track" vehicle so to speak she has quite a few mods to make her a little peppy.
Videos of hemiloredo03 in regards to locking 3rd gear during WOT. He is now running 11's on a stock block.
http://www.youtube.com/watch?v=fgPgAncpFfY&feature=related
http://www.youtube.com/watch?v=m6yr...DvjVQa1PpcFNqZ4-_T2V53QSrKP1UxnTythxD5ifDdzI=
http://www.youtube.com/watch?v=gJal...DvjVQa1PpcFNqZ4-_T2V53V2zDVm6v_ofp-D89PolPVc=
video of dline on stock block
http://www.youtube.com/watch?v=P1rIR4qduV4&list=UUQj8TFgO2VvNv369AfLEnaw&index=11&feature=plcp
1 - 4 of 4 Posts
