1 - 1 of 1 Posts
My project is to wire the cargo lights to come on with the reverse lights. Plan is, to put a relay across the reverse output, closing contacts on the relay. Contacts will be across cargo light dash switch contacts.
Problem is, wiring harness feeding main light switch panel is of the modular type, too small to make hacking possible. May be easier to access the cargo light wires via a conventional harness further up the line. Reverse output is no problem; can access from the trailer harness if need be.
What I really need is a detailed wiring diagram.
Anyone have a link?
Thanks.
1 - 1 of 1 Posts
