Need a little help here. Wires burnt through to the evap pump including loss of connector to it. Purchased one as below in pic. Have loose wires (which I believe were once to it): violet/blue stripe, violet/white stripe and black. I have assumed and tested black as ground. Violet/blue I have read is control circuit (12v) and violet/white is signal (low v) circuit. Does anyone know how to mate to this connector? If black (ground) is center...to which do violet/blue and violet/white mate? Which is 12v supply, which is signal?
