1 - 3 of 3 Posts
After a week of driving the truck around I've ran into another issue... the truck now goes into the gear limit setting on its own.
The two times the same thing happened. I was at a red light. Light turned green, drove straight and it was in D1. I quickly switched to D2 and waited to change into each gear accordinly then it turned off and went into normal driving settings. Could this be the hill assist kicking in? Will defintely have to go to the dealer on monday now.
It might be programmed that way for a reason, maybe its a break-in period to take over any of your commands, for now (???)
It`ll be interesting in what the dealership tells you. I would be VERY surprised if they could give you a straight answer. (without lieing to you)
I would test drive another truck identical to yours to see if it does the same thing, and have the tech ride along.
1 - 3 of 3 Posts
