1 - 1 of 1 Posts
Discussion Starter #1
Good morning everyone. I did my due diligence and hit the google box before coming here. So I just installed a 2nd amp, all new door speakers and dynamat. As you may or may not know, to install the dynomat correctly, You have to remove the inner door liner which has about 10 plug connections involved. I was careful to reinstall everything the same way to removed it. When i started the truck my engine light is on. I used my scanner and almost all the faults are loss of communication to several different modules (see attached photo). I cleared the faults but the come back immediately when I start the truck back up. I thought someone on here might be able to help before I start ripping the truck back apart to check all the connections. Thanks for any help or guidance.
133516
1 - 1 of 1 Posts
