New wheels on my 2011 sport
4179 Views 18 Replies 14 Participants Last post by  BlackHemI
Took me forever to decide to which route to go with my wheels but finally just went with these.
Fuel Krank. 20x10 -24 offset
Already had a 2.5/.75 rough country lift level, and bfg at ko 285/65r20 on stock wheels.
Im eventually going to go to a wider, more aggressive tire like the toyo mts I used to have, but because these tires are only a few months old, I decided to use them till they are finished.
So heres the set up, no trimming, no rubbing. Sticks out about 3 inches past the fenders, which is the look I was going for.
See less See more
1 - 19 of 19 Posts
looks good man!
Man , looks great, IMO fuel has some of the best looking wheels out right now
Sexy looking rig man, wonders what a little face lift does.
Keep it up!
Beautiful !.. Perfect for your truck.. Couldn't get better IMO.. Nice job !
I like it! Nicely done
wow!!! LOOKS AWESOME!!!
Your truck looks awesome man
Looks great! What else do you plan on doing?
Thanks guys.
I was going to put the 1.25 rcx body lift on top of the leveling kit, but have decided I wont be satisfied and to just take the level out and go with a full 6" kit.
Once the bfgs wear out, Ill replace them with some 35x12.50s. I know I can fit 37s with the lift but I dont need to make the 3.55 gearing or fuel milage any worse!
That's a beefy rig man, it looks great!! Are you going to black out the headlights as well?
Love the mirrors as well !
Hoping to put a set of polished Kranks on 2013 2500 as soon as I can order it and get it. I most likely won't lift it, but may well level it. I've been looking around to see a set of these on a truck so I could see how much depth they had back to the spokes. I'm not familar with your "-24" offset. I'm assuming mm ??? Could you explain it for a dumby please? I was thinking of getting 18x9's with the std 4.5" setback with a set of slightly wider 285/65/18's over the stock 265/70/17's. The Laramie has flares and I don't know what I can stuff under it and am not up on offset enough to feel cofident about changing handling characteristics, warranty, and safety issues. Also do you know if the polished Kranks are clear coated?:4-dontknow:
Great looking truck. I like everything about it. I'm considering white too. Hoping maybe there will be some new colors for 2013 too.
See less See more
looks dam good. nice wheels.
a -25 offset is about 1" from the centerline of the rim. That pushes the wheel out from the vehicle. The stock offset is +19.
Your truck looks awesome! Some inspiration for me, and my white Ram!
Hey Phildo, I noticed your mods list in your profile says 1.5 rear and 2.5 front, but your original post here says 2.5/.75 . I was just wondering which is correct, because I really like the slight rake the truck still has in your pics!
Oh or is it 2.5 front 1.75 rear? Is it this kit? http://www.roughcountry.com/suspension/4wd-dodge/1500-ram_2.html
love the white and black combo! :rep:
1 - 19 of 19 Posts
