1 - 6 of 6 Posts
Discussion Starter #1
Hi there
Ive got an 04 Hemi Ram with only 125k on it
I bought the truck with a rough idle and a check engine light for an evap leak.
$800 later ive got new plugs wires and boots
The misfire returns
New Egr valve, new cps
Misfire returns. Find theres a slight surging on the throttle body. $230 later on a new one
Misfire returns
Find one of the nipples on the rollover valve on the tank is busted. I drop the tank and fix it.
Misfire returns
New IAT, you guessed it
Misfire returns
Go to the dealership for diagnostic.
All new o2 sensors.
MISFIRE RETURNS
Im kinda at my wits end. Ill fix something and the truck will run great for a few days. Then the misfire will come back, but only on startup. If i drive it for a minute it goes away. Then it will get worse a few days later where it misfires all the time.
Ive tried running injector cleaner through the tank, ive 93 octane, ive done relearns
Am i at the point of checking the valve springs for cracks? Should i be doing compression tests?
The misfires show from random cylinders so my mechanic and I cant even isolate it
Please help!
I had a similar problem. Do you still have the CEL for evap leak? We found a small pinhole, when we did the smoke test. Also put gasline dryer/antifreeze and fuel system cleaners. Haven't had a repeat since.
What cylinder? You threw all these parts at it for a misfire BEFORE doing a compression test? Were there at least codes for these other things?
From
Hi there
The misfire returns
Misfire returns
Misfire returns
Misfire returns
All new o2 sensors.
MISFIRE RETURNS
Please help!
From driver side wheel well, look toward cab, top of tank near cab wall for a multi-plug. Its fuel line plastic nipples break.
The fix is cut it square, drill it and CA glue in a plastic fuel nipple.
Ruff idle ----- replace iac and clean the throttle body. check air plenum to TB gasket.
Bills86e
Clean TB yes, TB o-ring yes (but not likely) but can't replace just IAC lol (and he's already replaced the TB)....hemi has a computer controlled throttle body and it's integrated into and controlled by the PCM. Guessing you don't have a hemi or truck newer than 2008 (all Ram engines after 2008 are fly-by-wire)?
1 - 6 of 6 Posts
