I have a 2003 dodge ram SLT that won't blow cold or hot air, the blower fan works like it should at low or high speed. Also the vent location won't change, only blowing out of the front dash vents. Already replaced the HVAC Control moduel. I did notice the blend door actuator door itself was broken sitting on top of the blower fan, and removed it. The actuator moves the gears when changing hot to cold on moduel. Got a new door(no installed yet) but highly doubting this will fix the no heat or ac issue. Anyone have an idea of how to fix this issue. Summer is creeping around the corner and in FL AC is a must.
