Thursday I was getting off the freeway and as I slowed down, all the indicator lights on the cluster started to go off and the bell sounded. Every indicator went to zero as if I had switched off the power. I thought the truck had stopped running, but it was still driving and running. Then a few seconds later it all came back and the indicator lights went off.
Drive it Friday to the garage where I park and no issues in the morning. After work I get in and take off to leave the parking garage and it all happens again.
This morning I went out and did the thee key cycle thing and it said "no bus". I also did the trip reset thing and the C-Check reported A9,AA,AB,AC,AD,AE.
I went looking online and one person had mentioned the same thing and was traced due to a canbus wire in the steering column that was intermittent. By today the lights and alarm were going off regularly every 10 minutes or so. Then I remembered that in Wed I was out off-roading and after a stop I had adjusted the tilt on the wheel, So I tried to find the exact position I had the tilt before Wed .
After playing a bit I have it so I do not get any more alarms. I think this is just affecting the instrument cluster. I do not think the cluster needs replacing though. So far it has not done the light up routine since I "fixed" it.
Not sure if this will hold. Has anyone else had experience with this? I know I will have to take the column apart and locate the wire, but I just don't have time right now.
