1 - 3 of 3 Posts
Plugged in a sketchy trailer into my truck and the next thing I knew, no dash or clearance lights. When I pull the head light switch the dash lights up for a second then goes dark again. I have break lights signals and headlights still.
Tried replacing the head light switch, did nothing, I'm completely baffled. Fuses are also all good.
Did you check you relays while checking the fuses?
Discussion Starter · #3 ·
Yes. Changed a couple around as well as tried new ones.
I had also plugged in my cargo trailer, I know that one is working properly, and again no clearance lights or dash.
It's just strange. Bulbs are all fine too.
1 - 3 of 3 Posts
