My heat and a/c work but only blow out of the main vents, regardless of which mode (blend) is chosen.
I had it at my local garage and was told the mode door actuator needs replaced, for $650. Wow! He said mainly it is because the whole i.p. Must be removed.
I bought the actuator for about $20 and followed several YouTube videos on how to do it. I took it all apart, replaced the actuator, and put everything back together.
Unfortunately, no change, meaning, still no defrost. When I turn the blend selector knob, I notice lights dimming ever so slightly, like something is drawing power. But the air doesn’t change.
Is there a different problem? Or do I also need to change the actuator next to the glove box?
2003 Dodge Ram 1500 Laramie
