1 - 6 of 6 Posts
Discussion Starter #1
I have a 2013 Ram 2500 Hemi Laramie I am getting heat on the passenger side and cold air on driver side. I crank up fan and it is not blowing very hard either. I have flushed heater core, checked actuator to make sure blender doors are operating and still nothing. I am running out of things to research. Hoping someone can help.
Premium Member
Dodge has not changed much when it comes to the climate control system
Check out the videos on HeaterTreater.net for Dodges
There are 3 videos that cover almost every thing about troubleshooting the system
Tested all of the actuators - they all were fine. Mine ended up being a plugged Heater Core and a dirty Evap Core that was slowing air down on that side. I replaced the core and cleaned the ac evap and that fixed everything.
the heater core is the issue for no heat on the driver side for me it was anyways see this link https://www.youtube.com/watch?v=BfFnC0hayyw,
in the video he talks about the passenger side but i think for trucks it maybe the opposite.
first thing i did was switch the two hoses at the water pump to reverse the flow , after that i had heat on both sides for about 5 mins, then it went cold again, i then proceeded to take off both hoses filled the heater core with windshield washer fluid and blew it out with air 20 lbs alternating between the hoses , tons of dirt came out i put it back together and now i have heat on both sides pass and driver side , the reason i used air and windshiled washer fluid is that it is -35 C here and anything else would freeze , i think there is likely more dirt in there , once i can get it in a heated shop with water i will flush it with a garden hose , but this seems to be working for the time being.
1 - 6 of 6 Posts
