Just bought my first dodge last week :smileup:, the truck starts off in what I assume is second gear when you are in drive and also has no overdrive at higher speeds. I know that first gear is good because you can manually select 1 on the shifter and it works like it should; You then have to shift into second, and then drive for third. There is no noticeable shift to fourth either. I already tried replacing the governor pressure solenoid because I have heard that this is a common cause for a no first gear condition, but it made no noticeable difference. I did not replace the governor pressure sensor or any other solenoids at the time because the parts stores around me did not have them in stock. I tried swapping a different ecm from an identical truck too. Would it be more prudent to try the governor pressure sensor and see what happens or should I consider rebuilding the VB while I have the pan down again? Also, any thoughts on the fourth gear/overdrive problem?
