I took the picutre today of the installed lights and realized that the opening in the bumper did not look right to me without the trim.
Well, after a bit of cutting and a little bleeding:doh:I managed to cut holes in the trim to fit with the lights installed. I just took the truck out for a spin and the light output is still great.
I have attached pictures of the install and also one of the correct plug that the wiring needed to be added to for my 2011.
The instructions show the wrong plug for a 2011 and it confused me when I found wires in that plug that were already installed where they stated to add wires to. I called the dealer and they gave me the information I needed to find the correct plug and where the wires go in that plug. I also found wires in the correct plug in the #11 and #16 positions I suspected at that point that my truck might be pre wired for fog lights, sure enough it is. I removed the wires from the plug and added the new ones. At least I know in the future if I change out the bumper for the fog light bumper the wiring is already there and I will just have to reinsert the factory wires.
In the picture I am pointing at the #11 position and the #16 position is in the same row all the way to the left.
