1 - 10 of 10 Posts
I have a new 1500 Limited diesel with the horrible nostril grille. Can anyone tell me if there are crosshair painted frame frilles that will snap/bolt right in?
Then what is ny new nostril grill worth to sell?
Super Moderator
Any 13-18 grille will swap right in, except for the rebel grille.
My 2018 2500 has the “Ram snout” grille. When they first came out, I thought to myself what a hideous monstrosity it was. Over time I’ve grown to like it- a lot. Maybe give it a little time, you may feel the same way. Just a thought.....
Super Moderator
This is the 2018 section, so I was assuming that's what the OP had
I would trade the nostril grille (painted) with my crosshair in a second - including both sets of grille inserts.
I like the painted versions, ever since seeing the hydro blue one.
You are in a good position. The nostril style, while not everyone's favorite, is a very popular grille and you can easily swap in cross hairs if you have the desire to do so.
Where are you located? A local swap with someone would be ideal since you can pull the grille in 2 mins. You could make an on site swap with someone and probably make a couple hundred bucks to boot.
Also what color cross hair grille do you need? If it happens to be Bluestreak Pearl I know someone that would swap with you in a heartbeat!
Good luck!
If your nostril grille is white I will trade you my gloss black "night edition" crossbair grille assembly off of my 2017.
1 - 10 of 10 Posts
