1 - 4 of 4 Posts
Discussion Starter #1
I recently bought a 2019 Long Horn
The odometer says 19,000 Kms but when playing with the navigation I found a tab say info by pressing I found out is showing as 37, 000 Kms just to make sure I drove about 80 Kms after noticing that and checked the navigation info now ist showing 37, 080 Kms
Has someone tampered with the actual Kms
The navigation info is correct?
Pls help
Thanks
Can you tell me specifically how to access the NAV function that shows distance traveled? I cant find it
I finally found where it is displayed but it is only available on SOME versions of the software. When in the NAV screen simply tap on the I for information at the bottom. If yours has it that is the display. Mine is a June 2019 build and DOESNT have this info at all.
1 - 4 of 4 Posts
