1 - 8 of 8 Posts
oil filter is in a canister on top of engine, bottom left of engine cover
24 mm Socket Works
Yes for 24 mm Socket . Be careful of Aftermaket Filters . I am Using a Wix Oil Filter and "check engine light " came on. The Scanner says low oil pressure. Read another thread where a Bosch filter was used and oil pressure was 16psi compared to 30 psi with a Mopar Filter at Idle
I used a Fram on my caravan 3.6L this past oil change :4-dontknow: never had any issue so far, I change my oil every 4500 miles on wifes cars because she drives hard. and run synthetic after the 2nd oil change.
I love the oil filter cartridge location on the Pentastars, very easy, mindless and clean to change. Lot easier than my Ram HEMI.
Only using the MOPAR filters. bought 6 of them when one seller had them for $4.49 each.
1 - 8 of 8 Posts
