Take a look at this discussion:
www.ramforumz.com
RAM 1500 INTAKE MANIFOLD LEAKING OIL... BOLTS ARE LOOSE
Hey team! My 2014 Ram 1500 with about 50K miles is leaking a little oil down the back side of the motor passenger side. Not much just enough to wet the area. I read that the intake manifold bolts heat cycle and lose torque due to gasket compression and plastic heat cycle compression. Some...
