1 - 3 of 3 Posts
If a truck is experiencing a oil pump problems, would the truck experience power issues throughout all gears from take off to cruising speed. Would it idle rough or stall, what would the signs be for a oil pump problem. I just got my oil pressure switch done ( previous thread )
I'm trying to isolate the issue , from my previous threads. My Haynes manual doesn't help at all when it comes to isolating a power loss at a certain speed and cruising rpm.
Thx
Can you have the PCM scanned? It really helps isolate problems if there is a stored code to go off of. Your issues could be so many things.
Discussion Starter · #3 ·
When the garage installed my new oil pressure switch , they scanned it and received zero codes. That's when they said drive it for a bit and get back to them. I still had some lag and issues reference my previous threads.
As of now I changed my sparks to oem mopar and cleaned the throttle body out.
I will add seafoam to it tomorrow morning with premium fuel
Thx
1 - 3 of 3 Posts
