1 - 8 of 8 Posts
I have just imported a Dodge Ram - 2007 4x4 from USA to Sweden.
In Sweden we must have orange turn signals to drive the car legal on the roads.
The 2007 ram only have 2 reflector in the tail light so I bought tail lights from a 2006 ram with orange turnsignal on the upper reflector.
I also have the connector plate from 2006
I want it to be like this.
Upper Reflector: Orange turnsignal
Middle reflector: Red parking light and brake light.
Lower reflector: White reverse light.
How do I do with the electric wires?
I'm not sure if I'll be able to help or not...
Can you post a description of the wiring harness and the new connector harness? It will be helpful to know how many wires and what colors they are on each.
You willl jut have to make your own turn signal harness off of the existing one. You will need to find out which is the turn signal signal wire and tap into it to run a line for a new bulb
· Premium Member
go to this site, it is INTERACTIVE
first pick the year
http://www.rambodybuilder.com/year.pdf
then the model
then look for TECHNICAL INFORMATION
then Electrical wiring diagrams
then you can either click the location of the wiring or the page number beside it, whichever works
What is the lens color over those top 2 reflectors? I've been curious about doing this same thing despite being here in America and haven't been able to figure out how to turn the top reflector area into an amber turn signal while having a red lens.
1 - 8 of 8 Posts
