1 - 5 of 5 Posts
Discussion Starter #1
My 2000 Ram 1500 SLT was showing code P0720 which was The output speed sensor and I changed the sensor but it still showing the code...Could that mean that it’s actually the wiring/connector for the sensor or???
Most likely.20 year old truck likely has green death in one of the connectors somewhere between the sensor and the PCM.Could also be a worn through wire somewhere also.That's the problem with code readers,you get that code and you automatically think it's a bad sensor.Hardly ever true.
1 - 5 of 5 Posts
