1 - 12 of 12 Posts
Discussion Starter #1
Hello all. Anyone know how to remove the overhead console. I have new bulbs coming soon and ive never removed it before. Dont want to wreck it. Thanks.:smileup::4-dontknow:
Resident Technician
OVERHEAD CONSOLE REMOVAL
  1. Disconnect and isolate the negative battery cable.
  2. Remove the overhead console retaining screws, located in the sunglass storage bin.
  3. Using your fingertips, grasp the sides of the overhead console and pull straight down evenly to disengage the two snap clips at the front of the unit.
  4. Lower the overhead console far enough to access the wire harness connectors.
  5. Disconnect the EVIC, CMTC electronic module and the reading/courtesy lamps electrical connectors.
  6. Remove the overhead console from the vehicle.
Discussion Starter #3
Randy..........Im not sure if i called it the right name. This has the compass/temp outside and info display. I have no sunglass holder.2003 ram.:4-dontknow:
Resident Technician
That's what comes up for the '03. I'm thinking there may be more than one design but the procedure shoould be similar.
Discussion Starter #5
Thanks Randy............I will take a closer look . Maybe post a pic when i get home. Thanks again.:smileup:
E
Open all the doors on it, bones and look for the screws...that's the hard part.
Discussion Starter #7
Thanks Maddog. Looks to be a small door to pop open in the center of it.Just dont want to bust it or anything.:doh:
E
Like Randy said, remove those screws then firmly grasp the front of it and pull down. It will resist but just keep firm pressure on it. Don't Yank On It!
You can do it!!!
Discussion Starter #9
Thanks for the replies all. I came home and took a lokk. I poped the lens off and bingo.................1 screw in each lamp spot. Took them out and gave a lil pull at the front (Randy) and she came right down. Unpluged the harnesses and she is good for paint and new lamps./ Thanks a bunch.:smileup:
Discussion Starter #12
Thats exactly the same in my 2003 ram. Two screws out and a good pull down at the front and bingo. Just waiting for me bulbs.:4-dontknow:
1 - 12 of 12 Posts
