I have had this truck since the end of 2017.
Shortly after purchase the a Check engine light appeared, P1004 Short running valve. Dodge technicians ended up replacing the intake manifold.
Shortly after, the same code appeared again, I took it back and the techs then replaced the intake actuator.
After 2 days the light came on again with the same code, took it back to the dealership and they replaced or installed capacitors.
On the journey home from the dealership the CEL repapered again. I took it right back and it scanned as another P1004 issue.
I'm due to take it back to the shop today.
Does anyone have any experience with this issue?
Thanks.
Thanks.
