G
·The oil message is puzzling. I wonder if this is the first time it has had synthetic oil in it.
Try resetting the code. You can do that at an auto parts store or by simply disconnecting your negative battery cable for 15 - 30 minutes, then re-connect and start the truck. If the code comes back it may probably just be a bad oil pressure sensor.
You have a bad EGR valve so change that out and the first two codes will go away after you reset your PCM.
