P3497 MDS Rationality - Bank 2
Possible CausesSetting Conditions
- Insufficient oil pressure acting on the lifter locking pins
- Oil passages are restricted
- Valve lifter has failed
- MDS solenoid connector is damaged (check pins for damage, and moisture)
- MDS solenoid has failed
Engine running; then during the transition from 4-8 Cylinder mode, the PCM detected the O2 sensor readings on Bank 2 indicated a lean condition while in 4-Cylinder mode. Once all criteria are met, power is supplied to the Multi-Displacement Solenoid (MDS) solenoid while the engine is making a transition from 8-Cylinder mode to 4-Cylinder mode. By actuating the solenoid, oil pressure is raised to the pair of lifters that coincide with each particular solenoid. The oil pressure pushes in the locking pins which allow the lifter to collapse, decoupling the valves and camshaft.
This code sets in 1 Trip(s).
This code will turn on the MIL (Malfunction Indicator Lamp)
