I may sound pretty dumb asking this but on my kenwood connection there is a fuse on the battery line, and if you look on the PAC connection there is a fuse too, but it is between the pac and the OEM adapter to the truck, is having both of those fuses there a bad thing??
You can see in the image the black box off the yellow wire from the pac to OEM adapter (GREY)
As well the left box (WHITE) has the fuse that runs from the deck adapter that is supposed to be wired directly to the OEM adapter
Any info is useful, Thanks!
