1 - 15 of 15 Posts
Discussion Starter #1
Hello All! I am having a slight problem with my 2013 Ram 1500 Big Horn w/ 5.7 V8 HEMI. I started getting this "parking light out" message on my dash after I brake. It goes off in a second or two. Also, it is only when the parking lights or headlights are on whether manually or in "Auto" mode. There are no aftermarket lights installed. Have done a look-over with multiple persons and can not find anything out of the ordinary. I did take to a Ram Truck Center and had a tech to look at and they found a light bulb that had a loose filament. They replaced and said I was good to go. I got into truck and drove away not noticing that the headlight selector was in the OFF mode. I turned it to Auto, Parking, and Full Headlights and the message re-appeared. Has anyone ever had this happen to them or heard about this? Any help will be graciously appreciated!
Ricky
:4-dontknow:
Discussion Starter #3
Tried that and even tried a new bulb/s and still get the same message. I am at a loss. Got an appointment with the dealership again to try and diagnose it thoroughly.
Ricky
Ricky
Hi Ricky,
I'd be happy to follow up with your dealership for you if needed, just PM our page with your VIN and let me know!
Andrea
Ram Social Care Specialist
Discussion Starter #5
*update* 2/14/2017
Guys/Gals,
Here is an update report of "Parking Light Out" message when braking. Recap: I would get the message upon initial braking anytime the lights were ON. In other words, they would have to be on in order for this message to appear. If they were in the OFF position, nothing would happen and everything would seem normal! If I had the headlight selector on Auto or w/ parking lights on or w/ headlights on, the message would appear when I apply the brakes.
I purchased this 2013 Ram 1500 Big Horn from a CARMAX near me. However, since it was a good drive away, I decided to take it to a Ram Truck Center. They looked it over and said that they found a faulty bulb where a filament looked to be hanging and/or loose. Did repair at no charge. Got back in truck and pulled away not noticing that selector was in the OFF position so therefore, no messages when braking. I turned selector to headlights ON and low and behold the message appeared every time I had to brake.
I took some advise to just take it back to CARMAX since I was well within my 30 day warranty with them to see what they could come up with. Needless to say they also said they found a faulty bulb and replaced it no charge. I got on my way and before I got to far, I wanted to test it myself and guess what, "Parking Light Out" came up. Called service rep I was dealing with and he asked me to come back and him and technician would come out so I could explain what was happening. I went back, technician came out and I explained the whole deal on how the parking lights and/or headlights had to be on in order to get the message and that if they are OFF, you will not get anything. He took the truck back and in about 15 minutes he brought it back to me and stated he could not get it to go off and the I practically now have new lights all around. He said he check the computer (theirs) and seen where they may have to flash the system to get it to go off and that it is one of those deals where they need me to go to a dealership.
I made an appointment at a ram dealership near me (not the same on as before) and went straight there from CARMAX. They looked at it for about 30 minutes and found that I had a bad socket. Unfortunately, they didn't have it in stock. He said he ordered some since he wanted to have a few in stock there and that it would be around 60 bucks for repair. Made appointment for next day and brought the truck in. Wasn't there but about 20 minutes and they replaced the socket (can't remember if it was the rear driver or passenger side) and flashed the system. Got in truck, while still at dealership, and tried braking with the lights ON and NO MESSAGE APPEARED! YESSSSSSS! EUREKA!
Called CARMAX and spoke with service rep that I had worked with since he wanted me to call him anyway, as well as the technician, and told him what was found and what was done. He said for me to fax him over the bill and they would send me a check to reimburse me for the repair.
As of the writing of this UPDATE. Everything is working as it should. So much that I have been looking at some LED lights. But that is another topic for another forum post!
:smileup:
Super Moderator
Glad to now you got it fixed and reimbursed; seems Carmax is good for their warranty. Thanks for posting both your problem and solution-that is what helps members who may have this in the future
Guys/Gals,
:smileup:
I am having the same issue on my 16 ram 1500,
I can replace the bulb socket myself in the tail lights
but my dealer wants 120 dollars to reflash the system.
Can I disconnect the negative on the battery and do a hard reset to solve that issue??
My son had this problem with a 2004 1500 and would get a intermittent ding while driving saying he had a bulb out. He got a new socket assembly from Rockauto for something like $14 and 10 minutes work and all fixed.
No - I tried disconnecting the negative side of the battery and left it disconnected for a half hour and connected it again and still same issue
Andrea,
Would you be able to help me out with that same issue with my 2016 ram?
Hello MarkoR,
We can look into this further and see if there is any assistance we can provide. However, it is likely a dealer visit will be needed as our team is not mechanically trained ourselves. Please send us a private message with additional details.
Julie
Hello,
I replaced my OEM tail lights with SPEC D LED tail lights on my 2019 RAM 1500 “Classic”. Everything works fine, but as soon as I press the brake a warning appears on my display “parking light out”. It goes off after a few seconds, but returns every time I press the brake pedal. Please help.
Thanks,
Jeff
Super Moderator
Hello,
Thanks,
Jeff
LED's have a lot less resistance than incandescent bulbs so the truck thinks you have a light out. You'll need to add a resistor.
update 2/14/2017
Guys/Gals,
:smileup:
1 - 15 of 15 Posts
