Are you talking about the whole mirror assembly ?
Non Tow or Tow type ?
or
just the Mirror glass ??
Tow type or Standard
If it is just the Non Tow Mirror Glass, you can buy it from the dealerships Parts department for about $60 & once it is unwrapped, can be installed in 10 minutes, once a person has done it one time before
If you need the whole mirror assembly
once you have it unwrapped & have a cordless drill with a proper torx bit & a socket wrench & proper size socket.
You can swap out the whole mirror in 30 minutes, once you have done it once before
If you need the whole mirror assembly, you can get an after market assembly from Tony at 1A auto or from other sources
If you need the whole assembly & want to keep it completely stock, & body paint colored, you can get them through another of this sites vendors, MoparOnlineParts
both tow & standard mirror assembly replacing can be seen on YouTube
if you just want to replace a standard mirror glass, non tow type,
pivot the mirror glass down, stick your fingers into the gap between the top of the mirror glass & the outer assembly & give it a test jerk, pulling it towards your chest
If it didn't unsnap give it a harder jerk. When the top unsnaps, slightly lift & wiggle the mirror glass towards your chin, until the bottom clips release.
Then you just have to unfasten the 2 wires & use the old wire fingers on the new mirror
If you look at the date stamp, you will see orange paint, now look slightly to the left a bit & you should notice a piece of of Black plastic sticking up into the Orange paint, that is a 1 clip that holds on the puddle lamp
