1 - 5 of 5 Posts
Hi folks. I just had a mechanic change my fuel pump. It works okay, but now my panel is lit up like a Christmas tree.
-The Backup sensors are disabled, and I have no idea how to enable them(no option in ECM). Button on dash is ON and won't respond either.
-Cruise Control won't turn on.
-ABS indicator in. No idea why.
-ESP and $WD service indicators turned on..
Basically it's haywire.
I hear I'm supposed to Reset PCM.
I attempted to do it via disconnecting the Negative Battery cable method, but that did nothing.
I also hear I can Pull fuse #19,#23 or #31 method. But can't seem to locate info on WHICH on of those 3 .
Can anyone assist? Thanks in advance
Welcome to the Ram Forum " Z " Family :wavey:
Look up the underhood fuse panel diagram and find the "AutoShutOff/PCM" or "PCM" fuse location. Pull that one.
How long did you leave the cable unhooked for? It may take quite a few minutes for everything to discharge.
How would this be any different than pulling the battery cable? Or do some things still need to be powered on and only the PCM power killed?
1 - 5 of 5 Posts
