1 - 6 of 6 Posts
Covered under warranty I am not sure, I do know that anytime I bring the truck in for any reason, they do install the updates. One update was available for an issue I brought it in for in which I have not had any issues since.
2017 Ram 1500 Express 4x4
Can anyone tell me if any updates are covered under warranty or not.
Software updates of any kind are covered under the basic warranty which that component has. Example, a Transmission Control Module (TCM) update will be covered under the vehicle's transmission warranty. So, with a gas engine Ram, that would be the Powertrain warranty, which is 5-years or 100,000 kms. A radio update would be covered under the same warranty that the radio has, which is 3-years or 60,000 kms. PCM is a different one which falls under the Extended Federal Emissions warranty, which is 8-years or 130,000 kms.
Diesel warranties vary, so do Aisin transmissions.
They covered my updates but at first they wanted to charge me. I showed them the TSB said warranty and they checked and it was covered.
Can you tell me where you found that information? I can't seem to find it.
The dealership what's $350. For each update. I don't get charged for my phone updates so I don't understand?
Read some reports of dealerships not doing updates that didn't appear to be necessary (even in warranty) so I wanted to share my story.
I've got a 2016 Ram 2500 with the 6.7 with about 104,000 miles on it. I recently put a few gallons of DEF in and that night got a DEF message and to see the dealer. Engine light came on shortly after. Thinking the DEF solution was bad I took it in and just got the call from the dealer. Turns out that if you put more than a few gallons into the DEF take it does a type of self-check that errored out. DEF solution was fine but they said it was software-related and that there was an update to the PCM. Of course, I'm outside of warranty and they wanted $550 to flash and install the software. I choked but was about 50 miles from limp mode and asked the dealer if I had other options and he said no....
I'd be interested if anyone else experienced this sort of cost? If anyone has a non-deleted truck that's in warranty, they might want to get the truck updated before they have this issue.
1 - 6 of 6 Posts
