Where and what could I get to upgrade my cam in my 1999 ram and will I need anything else to apply the cam like lifters? Also what kind of carb should I go with edlebrok or holly?
that 4* basically just changes where the power comes in (advance = sooner(lower rpms)I did some looking into putting a cam in my truck and might do it in the future. I filled out a form on comp cams website on the type of things I was looking for and specs on my engine, etc, and got a email back from one of their machinist on the specs on the cam, a pretty aggressive one from what I can tell, had a 4 degree advance. I could be wrong though on how aggressive that is, not a cam expert. and was also advised by multiple people to get a pair of headers to go along with the cam to help the engine breath. another guy also mentioned a spring upgrade. that same guy bores and machines magnum engine throttle bodies, basically makes them like a racing throttle body, I think stock is like 48 or 50 mm? anyhow he can bore em out to like 50-54 mm I think, one of the big ones is recommended by him for a engine with a other than stock cam. I can get you his email if your interested. Im ordering a tb from him soon. Hope I helped a little.
