1 - 4 of 4 Posts
I have a 5.9 i bought with R/T heads, mopar performance ZUES intake manifold. It has a spun bearing so i tore the motor apart for the machine shop and found there was no plenum pan. My truck currently has a 5.2L that pings on loads and acceleration which is typical due do to the plenum pan gasket blown out. I am familiar with that repair. My question is, do the 5.9's have a plenum pan and gasket like the 5.2's? And if so, is it even necessary to install or can you do without.
Maybe your Zues Intake is a one piece intake. I know if its the original intake it requires the gasket and plenum plate. 5.2 and 5.9 are the same for plenum plates
Discussion Starter · #4 ·
Thanks for your help. That makes sense because the bottom of the manifold is flat all the way across and its like a high rise. You can fit your arm through it from both directions.
1 - 4 of 4 Posts
