So, I'm not really that poor, I just don't like the idea of spending big money on a lift kit. So I picked up some things from the wrecking yard earlier today:
-Shocks and leaf springs from a 2001 1500 Off-Road Edition
-Coil Springs from a 1999 3500 Cummins
All for $200.
Tonight I will be installing these and will post up photos of the process as well as before and after heights. It is possible that I won't like the full 3500 springs and might go back and get the coils off of the off-road edition or off of a 2500 gasser. But I think I'd rather raise the rear more than go back lower on the front.
A couple of things to note. Uncompressed, the 3500 Diesel Coils are ~18" long and are ~7/8" diameter material. The 1500 springs are ~16" long and ~3/4" diameter material. Not sure about the coil pitch, but assuming all other things equal, I should expect to get the 2" of initial lift as well as additional lift due to the stiffer springs. By my calculation, the 3500 springs are ~64% stiffer than the 1500 springs... so, if I originally had about 2" of sag from un-compressed to loaded, I should now have about 0.8". All approximations of course, but I should expect somewhere around 3" of lift in the front. I hope it's no more than that otherwise I'm going to have to start looking at additional suspension and steering changes.
I plan on cutting apart the leaf pack and adding in some of the leafs from my current springs. Essentially like an Add-A-Leaf (I don't like blocks). Only problem with that is that I'm not sure I can make up a full 3" by doing this. At least not without re-curving the springs. So I might have to make an extra block/shim to make up the difference... we'll see.
All for $200.
