1 - 5 of 5 Posts
I know this has been discussed at nauseam but here's my story. 2014 Laramie with panel filter, tune, Magnaflow with the Y Pipe mod. Figured a ported throttle body would be a good addition and it was. Got one, two actually, from Modern Muscle. First had a broken electrical plug the other had the throttle plate binding to the sides of the throat. When it worked the truck pulled hard. Lots of low down grunt and figured it would be perfect for towing. Want another and was going to look into Moe's. MMX had definate quality control issues but how is Moe's. Any issues with the plate binding or other problems? Very tough to talk to somethere these days as well.
2014 345ci 8hp70 44-44 3.92 Truetrac NX Express Comp Greene Racing
Save your money, unless you have a high lift camshaft with cylinder head work and longtube headers whatever you felt was placebo.
The 500hp 6.4 SRT engine uses the same 80mm casting throttle body, your 5.7L doesn't need any more intake cfm...
Oh, and Moe's is just a factory throttle body with a chamfer/taper to 87mm on the mouth. They don't even half shaft the blade for an extra 4mm of flow, not sure what MMX does but it's probably same.
1 - 5 of 5 Posts
