1 - 2 of 2 Posts
Discussion Starter #1
My 2014 Ram sport started having issues with the power door lock switches and key fob. This issue is intermittent.
I also have the passive entry system.
My doors would not always lock or unlock using the switch on both doors. Also the key fob would not always lock or unlock the doors. You'd have to push the buttons numerous times. Same with the door switch.
One day it has the issue other days works no problem.
At a loss. I've also changed both key fob batteries
Thx
I had a similar problem on my '17. It turned out to be the connector under the truck for the tailgate. It would get wet and short out. The connector is located by the spare tire.
1 - 2 of 2 Posts
