1 - 4 of 4 Posts
Has any of you ever thought about install a power inverter in the back of your truck ??
I wish to do it just for camping use, like put up an extra light for a bit, or to fill up my air mattress, or also if i need to do a light work but i would need a power source ! I think would be useful but i just don’t know what to buy..obviously i should need something water proof and small enough to hide in the back of my truck ! Any suggestion or video or also pic that you could post ? I was looking on youtube but more likely i hot video of 12 volt installed and they’re not so useful , thanks !
You'll need a larger gauge wire than normal for the longer run from under the hood to the bed to reduce current loss.
Discussion Starter · #3 ·
Yes i figured as much..i just don’t know how to do the rest of the wiring.. it’s obvious that i would need longer wire to make it happen..
1 - 4 of 4 Posts
