1 - 6 of 6 Posts
Discussion Starter #1
Looking for some help on how to replace the driver side rear door power lock actuator on my 2015 RAM 1500. All the guidance I have seen so far applies to older model trucks and the inside/configuration of the newer model has changed. I would appreciate any help on this! Thank you!
Premium Member
take off the inner door panel, then remove the black panel with all the electrical parts on it, you may also want to remove the window
then it is fair easy to replace the actuator
Bear in mind to remove the door module (carrier, black plastic inner panel), you will have to release the window from the regulator bars mounted to the backside of the carrier. This is done through the access hatch and the speaker cutouts. Just release the window clips and tape the window up to the top out of the way. You will also have to unplug the harness from the pillar and remove the 3 screws attaching the harness to the front of the door. Remove the latch screws and the bolt below it holding a window guide rail. Everything comes off as one unit.
1 - 6 of 6 Posts
