1 - 3 of 3 Posts
Since I bought my truck the power outlet and my cigar lighter do not work. Until now I have had no use for those. I have already checked the fuse and also replaced the actual lighter. It has to be something in between. Has anyone else had this problem?
· Premium Member
Have you used a 12-Volt Electric Circuit Tester, also called a Continuity Tester on it, to check your connectors.
It is one of the most useful tools in my roll-a-way
they only cost between $5 to $20, depending on the quality
http://www.mytoolstore.com/kd/kdbatt06.html
1 - 3 of 3 Posts
