1 - 3 of 3 Posts
Hello Folks,
I've got a power window problem with my 2003 4 door Ram...imagine that!
My problem seems to be a bit different that most though. Here is my problem:
Right rear (RR) window will not work from either switch, LF or RR
I have swapped the RR door switch with the LR door switch, but no luck
I have used the RR sw on the LR window and it works fine, therefore eliminating the possibility the RR sw is bad.
The LR sw works the LR window so I know that sw is not bad.
I replaced the entire LF (drivers) window module with one from a salvage truck but the problem persisted
I have jumped power directly to the PW motor on the RR and the window goes up and down just fine, so I know the motor is good....
Any suggestions now? Do these windows have individual fuses? That could potentially cause this problem, or just maybe the salvage module has the exact same fault as the module currently in my truck. Highly unlikely, but not impossible. Any comments will be appreciated.
Vinny
I'd try making an extra long jumper and test the connections between the LF and motor using a multimeter. Sounds like an open circuit.
1 - 3 of 3 Posts
