1 - 5 of 5 Posts
Sorry gang, newbie here and I hope my question makes sense.
Is there a factory foglamp switch available through mopar for our Rams? I am installing an N-fab bar with lamps I hope this week and I would like to keep them seperate from my oem fogs yet utilize a factory switch. I want to keep as much factory look as possible.
I did note another light icon on my gauge panel. In the far left just below the speedo, there is a light logo, so I'm wondering what it is for??
any help and your pics of switch installs would be greatly appreciated.
Factory switch for fogs, is just done by pushing in the light dial. The little icon you are probably seeing most likely in an amber color is the rear bed light. Your 3rd brake light reverse lights illuminate your bed. There should be a button for it next to your gauge cluster intensity dial.
Discussion Starter · #3 ·
^ no i found those just fine
the bed light is the dash light in the lower left corner in amber,
the Highbeam dash light is in the center and lights up blue,
the fogs are on the left in green.
If you look at your gauge cluster during the day you will see a fog lamp looking dash light on the far right side of the gauge cluster.
I will try and get a pic tomorrow during the day. hopefully someone can shed some light on it.
Your going to have to take that picture because if you have the premium cluster with the EVIC the only thing to the right of the speedo that you have is the following:
4LOW
4WD
Tow/Haul
Security Alarm Light
And maybe what you are seeing is the loss of traction indicator. It is similar to the one when you turn on traction control to the left of the cluster, but this one only turns on when your wheels start slipping. Otherwise I have no clue where you see that light. Sorry
Discussion Starter · #5 ·
^ I have the premium, I do see the 4hi/low etc lights, the lights is just above them, I will take a pic in the morning hahaha, it's funny no one ever sees them until the daylight hits the gauge cluster at the right angle and bam you see almost all the icons hahaha
1 - 5 of 5 Posts
