1 - 4 of 4 Posts
So I just bought my 2008 Ram 1500 SLT and I have some questions. First, am I able to switch "on or off" auto or 4WD while driving on the fly? Second, is there a traction control that can be turned off with the Key trick? Any info is appreiciated thanks bros...
G
You can switch from 2 HI to 4 HI at speeds up to 55 mph.
Shifting to 4 LO requires you to be at less than 3 MPH, rolling slowly, shift trans into Neutral, engage 4 LO directly. Do NOT put transfer case in Neutral.
There is no stock option or function to turn off traction control.
1 - 4 of 4 Posts
