1 - 3 of 3 Posts
Hi everyone, its been a while since I posted a question on here so I figured I would ask one and get a bunch of peoples opinion on it. I bought myself a rather large red light kit (for fire call response) and I am trying to figure out how I am going to run these lights. The front and Interior are taking care of but I am having a hard time locating a spot to run the wires for the rear lights into the cab to the boxes, I would not like to have to run them all the way to the fire wall and a friend of mine said I might be able to run it under one of the doors under the rockers (no luck finding a spot) the goal is not to drill more than I need to so if you have any suggestions that would be great (also pictures a plus).
Thanks ya'll
Premium Member
On my Ram i needed to run 2 Orange rotating lights at the back of my cab, i also needed to run a fuel pump for my auxiliary fuel tank.
The installer ran a hot wire from my battery to a small fuse panel that he mounted on the firewall & then into the cab to the 2 switches & another wire directly to my CB radio.
2 of the wires continued under the passenger side carpeting to a hole with a rubber plug it, then from there it goes to the underside of the Rams bed, one wire to each side & up 1/2 way of the stake pockets on one side & all the way up through the other stake pocket.
That's some nice install work! Also very clean truck. Don't see that a lot in escort trucks.
1 - 3 of 3 Posts
