1 - 3 of 3 Posts
Discussion Starter #1
This past weekend I threw together a quick set up in my 2010 RC. The storage compartment behind the seat was just the right size for 2 JL 8W3 in a tuned enclosure. So I cut out a baffel & port and sealed it to the top of the compartment. It sounds very good for the little time and effort it took. It is only a temporary install for me however, but I thought I would share with all of you.
Greg
Discussion Starter #3
It was right around 1.125cu. ft., tuned to 35hz. I ended up with a port length of about 20 inches, with a 4 inch diameter. Sounds good, the only issue I had was a little box resonance at higher freq.. I cured this for the most part by crossing over my amp around 65 hz. Normally I like 8's crossed over a little higher.
Greg
1 - 3 of 3 Posts
