1 - 6 of 6 Posts
I didn't know how to search for this one. Tried a few phrases but no luck
When I try to shift to drive it jumps from Neutral to manual +/- and jumps over the D. Truck still drives fine and shifts normally with no input. It just won't go into the drive indication and always indicates 5 in the manual shifter window. Watching the Tach it shifts normally through the gears. Anyone seen this before?
Super Moderator
The 5 means its in ERS mode, so it'll shift through the gears normally, just MDS is disabled. If you hit the (-) button it'll limit it to not shift past 4.
You have the column shifter or the slap stick?
Super Moderator
You aren't hitting the (-) button when putting it in gear are you? Its easy to do inadvertently with the column shifters
Discussion Starter · #6 ·
Thanks
Thanks for the input Thunderhorse. It was totally operator error. Had this truck since new, 2009, and didn't ever notice it do that in tow mode I guess.
Your comment on MDS turned on the light bulb...:thk:
1 - 6 of 6 Posts
