1 - 5 of 5 Posts
Discussion Starter #1
Vehicle: 2002 Ram 1500 with 5.9 L engine
Is it necessary to disconnect the transmission coolant lines since the transmission cooler is mounted externally on the radiator?
Like he said (and he does this for a living), your trans cooler is bolted to the front of the radiator similar to this:
You'll need one of those quick disconnect tools (cheap at harbor freight, also come in handy if you need to replace a fuel pump) to properly break the connections.
Discussion Starter #4
Actually, It is NOT necessary to disconnect either the transmission or power steering coolant lines on the 5.9 L engine in order to replace the radiator; I've just completed the job. Both the transmission and power steering coolant coils are mounted on the exterior of the radiator. It is a simple process to use twine to temporarily suspend the coils from the grille framework, remove the four mounting bolts, easily disconnect the tranny lines brackets, and remove the radiator without opening either of the coolant lines. Reinstallation of the radiator and attachment of the external coils is just as easy.
1 - 5 of 5 Posts
