1 - 4 of 4 Posts
Discussion Starter #1
So my ram 1500 has been having issues shifting it’s kinda sluggish . When shifting into 4th gear it bumps a little,when I get on it it hesitated and bumps . I changed fluid and filters as the fuild smelt burn I saw no chunks only normal wear and tear shavings . The check engine light tends to turn off by its self . I can’t find anything on the internet I feel it’s something electrical. Help would be amazing I just want my truck fixed it has the 65RFE trans and 5.7 hemi Tia
I had the same issue, did the same stuff you did. Dealership wanted to reprogram it$$$. I did the quick relearn w/alfaobd and not issue since.
Other than dealership or alfa, not that i know of. Alfa is $50 for the program and $25 for the obd reader. Dealership ship around me charge $120(minimum) which is at least an hour labor(even though it takes 10-15min max)
1 - 4 of 4 Posts
