1 - 3 of 3 Posts
There is nothing in the 2014 manual that states how much load to restore to the front axles when using a weight distribution hitch. Does RAM have a recommendation for this? 50% 100%?
Super Moderator
Stay within your GAWRs, front and rear and you'll be good.
I've never seen anything that details that either. Have you weighed your setup to determine how much is being removed from the front axle before engaging the weight distribution? I would say than anywhere between 50% to 100% restoration should be good - the closer to 100% that you can get the better.
1 - 3 of 3 Posts
