A while back I started getting some codes from the trans. Low hydraulic pressure, low transmission fluid pressure, and hydraulic pressure sensor circuit low.
Well I replaced the pressure sensor and also serviced the transmission (fluid and filter) A week or so later I got the P0934 code back, hydraulic pressure sensor circuit low. I clear the CEL and the code comes back about every 50 start ups (2 weeks) and only on start up. It seems to be completely random other than only throwing the code on start up and never while driving. Wiring from the sensor looks fine, any other obvious things I should check?
