1 - 3 of 3 Posts
Discussion Starter #1
Hello!!
I have mounted RCX 6" lift and got some problems.
The car was about 1" higher in front than the back.
Has received noise when I go from drive to reverse or vice versa, it slams somewhere. And even when I brake hard and then accelerate again I get the same noise.
Someone with the same problem.
Hello, did it begin immediately after installing the lift? I did a 6" lift on my 1997 and a week later it tore the carrier bearing out...made a loud clunk every time I put in gear or went from forward to reverse. Not sure on the newer Rams, but mine has a two piece propeller (drive) shaft with this carrier bearing. The fix was a new carrier (of course), but also had to lower the bearing block down about 1.5 inches to get the shaft out of the bind it was in
1 - 3 of 3 Posts
