1 - 10 of 10 Posts
Discussion Starter #1
I noticed a few days ago that there was a hose on the ground under the rear diff of my 2011 Ram. Closer inspection showed that the metal clips that attached the hose to the frame were rusted away. I rerouted the hose through a hole in the frame because I couldn't locate where the hose was attached from the factory. Can anyone advise where it goes, with maybe some pics?
Thanks!
I looked at mine and the end of the hose runs up behind the spare tire and the end of the hose is mounted on the frame close to the truck bed. Without a clip you could use a plastic zip tie. BTW did you ever get your spare tire down?
Discussion Starter #3
Didn't try today. Worked on the fiancee's Jeep Grand Cherokee. Has an issue with the Parksense system. Apparently there's a bad sensor, but I don't know how to find out which one or ones.
Thanks for looking at your truck. Was there a white plastic vent in the end of the hose, like the one under the hood? There isn't one in mine.
Thanks!
1 - 10 of 10 Posts
